im not gutting it, im puttin new efficient, lighter stuff in, once take all the stock stuff out, im spraying undercoat all over the floor, then im putting this type of insulation(not dynamat or any of that stuff) and it works real good, inexpensive. and it keeps your car warmer in the winter.
dont worry i have it all planned out, im not gutting the car
There are two ways. hot and cold. A heat gun can loosen the adhesive so you can pry it off. If it's very cold (Either really cold temps or by dry ice) it will shatter easily and come right off.
if youre dead set on removing it, dry ice is the way to go. freeze it nice and hard then just chisel it away and itll pop off in big pieces like other people around here have reccommended.
What is the stuff you're replacing the sound deadening with? Maybe take some pictures of the whole process...If the product you're using is lighter and better insulating then a little write up would be awesome.
well im going to spray the undercoating over all the floor, including over the tranny, and the new stuff is going all around, it was actually the easiest part to take off. and ya the tar is real heavy i wouldnt thing of it being that heavy.
well i dont really care about look because it wont be seen, my carpet is going back in so its like whatever, and ive heard rhino lining is hard to use. what about rock guard since thats like rhino lining
