Okay, this little component can be a major bugger to deal with in a number of circumstances. I may do a writeup on rebuiling them, but for now lets start with covering the stock values and modifying it to work with lighting that's different than stock.
There are two resistors which set the trigger values, we'll refer to them as R1 and R2.
I'd like to get some folks to post up the values of these resistors and which year and model they came from (include if the wing uses lamps or LEDs).
Unfortunately, I know very little about the two I have (and I haven't looked at the one in my car yet).
Here are the details from the housing and the resistor values:
Both housings have the same info:
89373-32120
068800-0872
12v 27Wx5, 8Wx4
from '88?
R1 = 24K re,ye,or
R2 = 35K or,gr,or
from '89+ (exact year unknown)
R1 = 22K re,re,or
R2 = 51K gr,br,or
Modification:
If you're running an N/A and you've added a wing you can either replace the resistors with those listed in this thread.
OR (and this goes for those installing LED replacement lamps in place or bulbs) you can install 2 100Ω 1/4W potentiometers and adjust them until the failure lamp no longer comes on. If you don't want to leave the pots in place you can remove them after the value has been found, measure the resistance and install resistors of the appropriate value.
![Taillamp Failure Module.jpg](http://www.fadingworld.com/Supra/TLF/Taillamp Failure Module.jpg)
89373-32120
068800-0872
12v 27Wx5, 8Wx4
from '88?
R1 = 24K re,ye,or
R2 = 35K or,gr,or
R1 = 22K re,re,or
R2 = 51K gr,br,or
Modification:
