the tach appears to be wired correctly in the jumper harness, but I still don't get a signal. I've searched with no luck, but I thought that I read there was another source to pick up a signal for the tach. Am I right?
Satan said:Hmmm... both of those wires go thru the M1 cpnnector... so, I'd check to make sure that you got connected to the right ones going to the dash/guages... Rick's got them mapped out here... http://1jz-gte.us/documents/SubDocs4/IG1-1990.pdf
Is the guage cluster from a turbo? An N/A (MKIII) tach does not seem to work well with any J-series signal.
rakkasan said:I thought that I read somewhere that there is problems with the 1J tach reading the signal. Maybe I'm thinking of an NA tach. Anyway, from what I recall, someone picked up the tach signal from another wire?!?!?
cormschr said:just because there is continuity between those 2 locations doesn't mean the tach will work. don't ask me why but when i was doing the swap i had continuity there and my tach still didn't work. i had to resolve this in other ways..
