t3 header for 1jz
rwd
60
quebec
i'm searching for t3 header for 1jz, they're hard to find.I don't understand that all online shop only sell t4.The only t3 i saw, is on ebay but they're look bad
is it ok to put an t3/t4 adapter on t4 header?
where can i find a good t3 header for my 3082r?
slideways2004
98
Houston
foreverpsycotic;1218568 said:
I have an XSpower manifold. Looks freakin mint. If you want, I will post up pictures of it.
please do. i'm looking for one also. i ended up buying the crappy ebay ones but i really don't like it
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Ask and ye shall recieve
Sorry for the shakey hand, its cold in my basement. Also appoligizing for the dust on these parts, I have been slacking hardcore.
BTW, that is dust on the inside of the manifold, not rust.
I thought XS power was the ebay manifolds. I have one of them as well in my garage. After Mike sells his, if someone else needs one, send me a pm.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
I aint sellin you silly hillbillie.
Although, if they want I can sell a full single kit minus hardpipes for 1200.
OH, my bad. I have two of them actually, but one of them had a small exhaust hole in it, but I had it welded up. The other one was only on my car for about a month and I decided to go with a Drewgo manifold. It was three times the price, but it was four times the manifold............:biglaugh:
rwd
60
quebec
where can i see drewgo manifold?
i already have xspower , but its like ebay stuff
i want flange angle for turbo and bigger wastegate tube ; like this:
but my question is , is this adapter ok ?? anybody already used this
rwd
60
quebec
Send a pm to Drewgo on here. He sells them and they are exactly what you want.
They come a t4 flange, but I drilled four holes in mine and then welded studs into them and installed my t3 flanged gt35r. I would have bought the adapter if I knew they made them though. That steel drewgo uses ate up about four drill bits and I also ruined a brand new tap and die set trying to thread the holes. I ended up having to weld in some bolts instead.
