T/B question
MKIIINA
Destroyer of Turbos
Plano, TX
it depends. for example im running the 2jz tb. changes that were needed ->
throttle opens opposite stock, you need a new tps to compensate or swap the throttle plate around. i got lucky and was able to get the 2jz tb to work with the stock electronics.
the stock flange is 63-65mm and drilled to fit the stock tb. you will need an adaptor.
the throttle linkage will need to be changed.
your question is a little open ended so if you had one in mind specifically we might be able to offer better info
MKIIINA
Destroyer of Turbos
Plano, TX
you would need the q45 tps as it opens the opposite way. i reread my previous post and i realized i was a bit vague, my tb uses the 2jz tps and connector that is wired into the stock wiring harness.
