synthetic oil question
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
I guess I should start running it also. I've been running the cheap Wally World stuff. Supertech 10W30.
I know...I know... :slap:
ZoomZoomZoom
On the road again..
Dec 9, 2007
443
KY
jdub;1244332 said:
German Castrol 0W-30....there's specifics in the Lube Section.
A lot of folks seem to be running it in Supra motors lately ;)
When I did research on this last year the German Castrol was getting more and more difficult to find. I went with the Pennzoil Platinum because I could get it here at WallyWorld. Obviously GC is still around, whats the best source for it nowadays?
deabionni
The Lurker
Sep 16, 2007
431
Kalkaska, MI
I get mine at Autozone, as that's the only place in my town that carries it. I also think that Pepboys carries it as well, but I can't confirm that as we don't have a Pepboys up here.
jdub
Feb 10, 2006
10,730
Valley of the Sun
PepBoys in Arizona carries it. AutoZone too.
Just make sure you get the right bottle...GC has "Made in Germany" on the back.
jdub
Feb 10, 2006
10,730
Valley of the Sun
For a conventional oil, SuperTech is actually not bad. SuperTech filters as well...made by Champion Labs, same guys that make Mobil 1 and K&N. I'd use a SuperTech any day over a Fram or any brand that Fram makes. That goes for the Toyota (made in Thailand) filters too.
AcIdBuRn02ZTS
227
Indiana
im a big fan of mobil 1 5w30... i run it in everything i own... from the wife's daily driver dodge neon (which saw a really decent mpg increase when i switched over to the synthetic)... to my 350whp ford focus... my supra... and my 83 k10 chevy w/ built smallblock....
ive noticed a few things... mpg increases over conventional oil was around 3-5mpg in most everything... not so much in the truck... but not too worried about that... the cars all run a LOT smoother while running the synthetic over the conventional ive noticed.... they also seem to run quieter (normal engine/valvetrain noise... not knocking, etc...)
i havnt tried to many others due to lack of availability in my area and costs... but im happy with it.
anyways... my .02
-AcId-
jdub
Feb 10, 2006
10,730
Valley of the Sun
anyways... my .02
-AcId-
Mobil 1 is a middle of the road Group III hydrocracked dino oil...it's not a "true" PAO or ester based synthetic. There are far better oils out there...if you are going to run a Grp III oil, Pennzoil Platinum is much better due to the hydrocracking process used to produce it and it's additive pack. Not too sure why you're such a "big fan" of a mediocre oil, but a little research just might change your opinion.
Wills7MGTE;1292542 said:
I run 10W-30 per the owner's manual for my 90 Supra Turbo. I've heard other weights used but I have neverh ad issues with my oil so I'll stick to what works.
A 0W, 5W, and 10W-30 oil all have nearly the same viscosity at engine ops temps...it's a API requirement to be called a 30W multi-grade. The difference is cold viscosity...a 0W or 5W-30 oil is lower viscosity cold and will flow better. The bottom line is any 0W or 5W-30 oil can be substituted for a 10W-30 called for in the Supra manual with no problem. You will get better flow cold and less wear as a result.
Will - you might want to read the Motor Oil 101 link in my sig ;)
