Switches wiring, need some electronic help!
bobpogoman
213
Quebec, Canada
ok guyes i bought some carbon-fiber looking switches for different application.
they have a led on them and have 3 pins to get connected.
1 pin have ground sign.
1 pin have + sign
1 pin have a light sign.
the thing is that i must wire my boost controller dual stage to it, the boost controller is grounded next to it, and i need to switch the 12v to it.
how could i wire this?
bobpogoman
213
Quebec, Canada
ok but where i connect my wire coming from the boost controller?
i tought about + to 12 v ignition switched
and the light thing to my boost controller..?
there must be a in and a out....
figgie
Twin Cities, Minnesot-ah
you are joking?
1st. Did you read the instructions that came with the boost controller. It did not come with them? Go to HKSusa.com or Greddy.com for the manual for each.
2nd off. WHICH wire?
3rd. You haven't even posted what type of boost controller it is! You can not be that ambiguous and expect help.
:icon_evil:icon_evil:icon_evil
bobpogoman
213
Quebec, Canada
calm down lol, its a turbosmart dual stage boost controller,
the manual say:
ground the brown wire coming from the boost controller,
extend the blue wire to the switch that come with the boost controller,wich is 2 pins, and simple as u just put the blue wire as input, and the output of the switch to a 12v source.
but im wiring it to a 3 pin switch with a led.
bobpogoman
213
Quebec, Canada
with the boost controller, it was coming with a 2 pin switch , no led or anything, red colored.
with the cf switches , no instruction, 3 pin 1 ground 1 + 1 light
