swapping 2jzgte jdm into MKIII
turbogate
Life is Boost
May 18, 2005
425
South, FL
90greysupra;1195131 said:
ive read that my year the engine will drop in besides the beating of the firewall 1" to 1 1/2" or whatever the spec is? with my 7m brackets and my driftmotion.com engine mounts.
Maybe it's a typo, but just to clarify for you. 7M brackets will not work. You need 1JZ brackets or if you can't find them, BIC brackets (which driftmotion also offers). Good luck and post a lot of pictures, I'll be right behind you with a similar project.
90greysupra
29
Michigan
you know this for a fact? because i thought ive read that it would drop in with the brackets i have already either the 7m or the 2jz? thanks
juhanis
2jza70
Jan 11, 2006
136
Los Gatos, California
90greysupra;1196002 said:
guess there goes $200 man i thought i could use my own engine brackets... oh well... do what you have to do to go fast....
haha yeah, its the first of probably many things you didnt know that you were going to need. when i got my engine, i heard that the pan was going to work, the flywheel wasnt going to be hard to find, i thought my mounts were going to work, etc... but its worth the work, trust me.
Dirgle
Conjurer of Boost
Pauma Valley, CA
Good luck man. I'm in the middle of doing this myself, and the devil really is in the details. All the little odds and ends that nobody seems to mention, and add up really quick.
Especially if you plan to stay stock. When people say it's easier to go single right off the bat they are not kidding. Also if you have the MKIV vs. the Aristo engine can make a big difference in how much trouble you run into.
example: The water neck on the Aristo sticks out farther than the MKIV version creating clearance issues with the fan.
The oil return elbow on the Aristo is angled for the front sump pan. When you put on the mid/rear sump pan you have to change the two 4in. sections of hose that connect to the elbow. and even the it places these sections of hose at extreme angles, and stresses that may shorten there longevity/reliability. That elbow can work but the best solution would be to get the MKIV turbo oil return elbow.
For the intake side the BIC mounts interfere with the intake manifold support brace. The brace has to be removed and two vacuum hard lines are riveted to it, that have to be drilled free.
On the exhaust side, my 87 engine mount(Not the BIC metal half, but the square rubber) interfered with one bolt on the Y-pipe coming off the turbo. You may not have this issue as your car is a 90 with the round mounts.
For the aristo motor, when your change over to the rear/mid sump oil pan the oil stick has nowhere to bolt to, a custom bracket has to be manufactured.
Those are just a few of the issues I ran into, there have been many more.
You may not have an aristo motor, so it may not mean anything to you.
90greysupra
29
Michigan
yea id bet it is... so you have the na 2jz did you put the oil squirters in for the pistons? i read on wikipedia that the only difference component wise between the engine were the oil squirters to cool off the top of the piston?
90greysupra
29
Michigan
I dont know if its an aristo or what it was from all i know is that it had a rear sump i took it off and thats as far as ive gone due to no parts ....lol money fund is short but christmas time is gonna help hahaha
mattsplat72
is sofa king
Jan 17, 2006
1,738
Hey Dirgle, Matt here I am over in Sedro would it be possiable to meet up and shoot this shit I am currently on my third 7m and am going to be getting a very large settlement from a work injury. I am on the fence between a 1j or a 2j. My hang ups are difficulty with swaping the 2j and the difficulty of getting parts for the 1j that wont take weeks to get here and cost alot. The pros are both sets can be had for roughly the same amount of money . Both have a good amount of support in Japan for performance parts which is no biggie as the supra isnt my daily. I saw Ron R's swap being done but that isn't a realistic example for me as that guy is like jesus with a welder.
Dirgle
Conjurer of Boost
Pauma Valley, CA
Well from the sound of it you got a MKIV 2jz, which is a good place to start. You'll see less issues than I did.
I'm always down for meeting a fellow supra owner, Just PM me when and where would work for you. I work nights M-F, so any time outside of that works for me.
90greysupra
29
Michigan
so found out recently that the engine i have is indeed an aristo model this is what she look like as of now.... tell me what you think i polished up the valve covers myself and have done all the work so far replaced all seals and belts.... t67 turbo .58 exhaust propeller. very pleased with how its coming looks awsome very nice and polished up...
