I want to swap my 1jz from a 90 n/a into a 87 turbo chassis. If I read correctly the only thing that would be different is the motor mounts. Everything else should just swap over. Correct?
JonoTurbo;1544718 said:The wiring will be different too, you'll have to wire in the 87-88 style dash harness plugs.
Kevin;1544721 said:unless you swap EVERYTHING over incliding the dash etc lol.
