Suspension settling uneven?
iwannadie
981
gilbert, az
Another thread...
I noticed my passenger side is about 1/2 inch lower than my driver side. Made no sense to me i figured if anything the driver side would settle faster since i never have a passenger.
I pulled the wheels off and everything seemed installed correct. Am i missing something or will the suspension take time to even itself out. Is there anything i should check or be looking at to sure its correct?
I hope i didnt blow the pass side already, its only been a week less than 200 miles :(
iwannadie
981
gilbert, az
starscream5000 said:
I've hear that a few people have had issues with Tockico struts blowing out often, check yours to see if there is any signs of a bad strut on that side.
Well like i said its only been on for a week, i cant imagine itd blow that quick. When i pulled it off i didnt see anything wrong with it.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Hmm, everything should be settled for the most part by now. I seriously doubt the fault is in the Eibachs, but you never know... The springs are seated correctly and not upside down right?
iwannadie
981
gilbert, az
Not upside down and as far as i can tell seated correctly.
I guess ill wait a week(if noone else chimes in) then pull them out again and remove the springs. Just to make sure they are lined up and the struts are ok.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
My monies on the struts. If not that, then could be the chance of an improper instal of springs (but if you've checked, then I'd say struts). My opinion only: Tokicos FTL :(
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
wellt eh only thign i cna really sujest be side blown shock and it does happen even when there new
the spring's may need to turn to be = with the rest but thsi very sim thou and be ajust tot eh stock grove
that por one of you tires is low lol
