Suspension Rattles! !!!!
noel
Uchiha Member
May 5, 2008
512
Miami, Florida, United States
im so piss right now i hope someone can help me!
on my 88t Supra with stock supsension the rear driver side has this rattelling noise when im driving and it get's worst when im doing 30-50mph:3d_frown:
i look at the TSRM online:icon_bigg_________________________________________
There's 3 bolts and the big one in the middle which is called the ''suspension support nut'' which is bolted down on the ''piston rod''
Is there supposed to be a washer or something under that NUT?
I cant get that "Suspension Nut" to come off... The Whole Entire Piston ROD spins and not the Nut what does that mean? when Push down on the car i can tell the " NUT'' is hit the Support Hole" which equals a Rattleing Noise
WHAT DO I DO GUY?:nono:
blacjack
9
Maryland
Yes, there is a spacer that goes under the nut. Same thing happened to me, couldn't get the nut off. Had to find a way to hold the chrome shaft thru the spring and high up enough so that spot wouldn't enter the shock when fully compressed and slowly remove the nut. Must be the correct spacer though. Rear struts only. If you gall up the piston rod too much, it'll have to be cut. Good luck.
noel
Uchiha Member
May 5, 2008
512
my tech. told me that my strut mount is bad so i order one from toyota and gave me the WRONG one ! !!! then they wouldnt take it back cuz i didnt have the paper work! so i had to buy the right one this time those's mother fu*****! i havent put the strut mount in yet maybe on sat.
Satan
Tampa
You want to make sure that you slightly loosen it while on the car, but DO NOT totally remove the nut until you have the spring compressors in place. Seriously... damage your car and may hurt yourself or someone else very bad.
noel
Uchiha Member
May 5, 2008
512
well i wont be doing the work lol im sure the ASe tech knows what he's doing! lol i just wanna make sure it's the strut mount...not to get off the subject but i was looking at intrax lower springs..
would lowering the car damage the tires or anything? i think it only drops it a 1.25 all around my car has stock ride height i wanna lower it the right way
No, there isn't supposed to be a spacer under the nut on the shock...
Yes you'll need a realignment after getting springs, but you may have to do it a few times as they settle.
noel
Uchiha Member
May 5, 2008
512
thanxz poodles that would be no problem since i work at sears auto i get them for free i never really heard of intrax anybody got anything on them? ebiach lowering springs dont drop the car low enough lol ...hey poodles i can use the stock struts with the lowering springs right?
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
if you have stock struts in your car, and your gonna put some lowering springs, dont expect them to last for very long. get some tokico hp blues or something... there only $200 for all 4.
