Suprastick + IS300 steering wheel, thoughts???
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
I was thinking about this the other day when I was driving my IS300...
Would you be able to use the suprastick with the IS300 steering wheel? It has the upshift and downshift right on the steering wheel. Not to mention that it is a little smaller and nicer looking than the stock supra steering wheel. You'd just have to figure out the wiring. I don't know too much about the suprastick because I have the R154. I was just throwing it out there to you automatic guys/gals. Here are some pictures of what the stock IS300 steering wheel. The center "L" comes off as well. You could probably replace it with a toyota one.
SupraMario
I think it was the google
7
The Farm
AF1JZ said:
yea, the buttons instead of paddles. It's just another option. I'm just curious just to know if it can be done.
Well buttons are just rocker switches so I dont see why not.
iamshawn
codename: HENRO
Nov 2, 2005
74
Houston
should work fine no problem. I wired one of those up on steering wheels that has 2 buttons for nitrous etc.. one side upshift one side downshift. Should work just fine with the IS300 steering wheels which would look much nicer than the stock supra wheels anyways. ^___~
