Supra won't start
TomFraser
I have a supra that drove about 60 miles then bogged out and quit
There was no pressure at the fuel rail, and the pump seemed to be working so I replaced both fuel filters
It started up after replacing the filters, drove it about .25 miles then back to my house and as I was driving up the driveway (steep hill) the car died.
Now I have no pressure at the fuel rail again, but the pump is making noises
one hint is that when I tried to start the car after the stall out the temp gauge went above H to the max the gauge can possibly go, If I pull the EFI switch the gauge acts normally
what else can I check? It is a fuel issue, but definitely not the fuel filters, any ideas? cranks strong...
TomFraser
error 32 and 51
A/C is disabled
error 32 is:
32 Air Flow Meter Signal(7M-GE)
HAC Sensor Signal(7M-GTE)
Diagnosis(Air Flow Meter Signal(7M-GE))
Open circuit in E2 or short circuit between VC and VS.
Trouble Area
Air flow meter circuit
Air flow meter
ECU
Trouble Area
Air flow meter
ECU
check your afm.
tubros have a air flow meter n/a's have a mass air flow sensor.
the afm is what controls the fuel pump once its started so that would be your trouble area since your not getting fuel.
TomFraser
dumbo;1330793 said:
Is your poopra a GE or GTE, and wha year.
Do you have fuel in your tank?
And 51 is related to the TPS also..
gte 87 completely stock, missing HAC... just ordered one
have fuel in tank (not much though, drained most to drop it)
Will take an ohm meter to TPS and some threads recommended shaking the CPS
mdr40z
arkansas
wow, just wow..... thanks for posting results however humiliating::hah::
I can't imagine what would cause that
