hi guys im nick i have a 1988 toyota supra turbo, ever since i got this car i have had a problem with it. its like the car has a mind of its own some days it will start first try sometimes it wont start at all. i could never figure it out. sometimes if i hit a little bump in the road the car will shut off and just crank and crank then finally after a couple minutes it will start right up and go like nothing happened. then one day i lost almost all my boost. im running a completely stock setup no mods at all running 6psi now it runs about 3psi max. thinking i have a boost leak took some piping off and see i have oil in my piping so my turbo must be blown. then one day when i was going to the gas station the car just sputtered really bad and died now it wont start. likes like i lost all my power the car ran sluggish. now the car starts sometimes not alot but when it does seems like its fine then once i hit the throttle it instantly bogs down like its going to die then it will die then i cant start it for the rest of the day.. the car wont start anymore it will turn over all day sometimes if im lucky it will act like it going to start actually run for like 5secs but really crappy.. i have check the fuel pressure have 38psi to the rail. checked for spark have that. the only thing i think is compression but i just dont understand why that would be bad out of nowhere. tell me why when i go to start the car sometimes the tach will jump up and down like normal then sometimes it wont move at all. thats how i usually can tell if the car is going to come close to starting if the tach is not moving or if it is.. please supramania help me out!! i love this car and dont want to give up on it but im stumped!
