supra not starting after clutch install
turbo2
59
hawaii
ok i just but an spec stage 3 clutch in my car i put everything back together and the car wont start. its got 12 volts and the fuel pump is working. could it be the afm ? i moved the screw back. i got an extra one just in case.o and the exaust is still off.
turbo2
59
hawaii
ok it does crank and i am in netural. the grounds are kind of dirty. should i clean them or find another ground?
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
There is a ground that comes from tranny by the output shaft that goes around the tranny mount and goes on one of the 4 mount bolts.
Check codes.
