Hello,
I have a Supra MK3 with 1JZ-GTE and the last couple of months I have an electric problem. When I turn on the ignition and the tachometer is "playing" an also if you go near to the top of the cylinder head you can hear sparks from the coils. If you start the engine it will run for a few seconds and then it will stall. If you start it again it may work for another few seconds normally and then it will stall again. While the engine is running the tachometer is "playing" ex the engine is idling at 900rpm and the tacho is instantly going to 2000 and back to 900.
I have checked the below
1. Change igniter (three of them)
2. Change coils
3. Change plugs
4. Disconnect crank and cam position sensors, MAP, idle control valve, TPS
I also checked the error codes in the ECU and I got 14 and 21. 14 is ignition feedback (IGF) error. As mentioned above everything related to ignition has been changed and I have also checked the wires from ECU to igniter and everything looks normal.
[video=youtube;wYb0gEUAg1E]https://www.youtube.com/watch?v=wYb0gEUAg1E[/video]
[video=youtube;QVxgck3NvQY]https://www.youtube.com/watch?v=QVxgck3NvQY[/video]
Any ideas??
2. Change coils
3. Change plugs
Any ideas??
