supra interior changes?
Jeff Lange
Administrator
4,922
13
Sunnyvale, CA
jefflange.ca
Most pre-89's will have the wiring for it, but not all.
No 89+ cars have the wiring for it.
Connector: (Ignore the craptastic pic)
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
canadian said:
Last question, is there any advantage of the 89+ climate control over the pre-89 climate control when you put it in a pre-89 car?
Well, look for yourself :) (same car)
Before:
After:
canadian
Newbie
May 16, 2006
366
Victoria BC
Wow, fotosoup, how did you know im a picture learner:biglaugh:
Those pics helped a lot. There is a WORLD of difference between the two.
Thanks!!
Before:
After:
Jeff Lange
Administrator
4,922
13
Sunnyvale, CA
jefflange.ca
jdmk3_87t said:
Clean-looking 86.5-88 CC's rock!
Here's a pic of mine...staying true to the 87! :biglaugh:
http://i16.photobucket.com/albums/b47/mightymijo/DSC08436.jpg
88 Looked nicer. ;)
Also, my hazard switch is on the left because I wanted it there. :) There is a coin holder where the hazard used to be. I wanted all the switches on one side instead of 3 switches and a coin holder on one side and 1 switch on the other. But then I got the new steering wheel and my cruise main switch moved there, so I ended up having a coin holder on each side, haha. I may still go to the 90+ illumination dial though, to eliminate my 2nd coin holder. We'll see.
Oct 11, 2005
3,821
25
Thousand Oaks, CA
The only advantage of the pre 89 controller that I can see is that you can have the vents on auto and the fan on manual (or vice versa). With the 89+ its auto everything or nothing. Actually, I need to go check mine at lunch! Maybe if you press the auto button, and then select a manual fan speed the vents stay on auto. The addition of the heater/defrost combo button on the 89+ was a major advance. I use that one a lot.
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
yes you can have the vents on auto and the speed on manual... or the speed on auto and the vents on manual.. with the 89+
Jeff Lange
Administrator
4,922
13
Sunnyvale, CA
jefflange.ca
^^^ What he said. In fact, the button I believe presses 2 seperate buttons behind it on the 89+, I had wanted to cut it in half so you could press each side seperately, but never tried yet.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Yeah, if I recall correctly, it is two seperate switches. The problem is the spring and armateur used to hold the buttons down while releasing the others... I don't think one of those two buttons had a catch to hook on the retainer and hold it down... just one of them did. I could be remembering it wrong, it's been a while since I rebuilt mine.
