Supra engines, are they even-firing or odd-firing?
te72
Classifieds Moderator
6,624
9
WHYoming
Coworker and I had a discussion yesterday about how Supra engines fire. I was under the impression that cylinders fire in pairs, i.e. 1 and 6 fire at the same time, 2 and 5, 3 and 4... He says that while cylinder 1 is firing, cylinder 6 is exhausting. Is this how our engines are? I tried looking into it a bit yesterday but couldn't come up with any good info with Google.
While 1 is on compressin 6 is on exhaust stroke. Wasted spark both 1/6 plugs are firing. Every 1/3 of crank rotation a cylinder fires.
A. Jay
Search.
Jun 3, 2009
671
Bay Area, CA
QFT
I didn't check if the firing order is the same, but watch a pair of pistons and notice the alternating power strokes:
[video=youtube;NNqmNqaZlKA]http://www.youtube.com/watch?v=NNqmNqaZlKA[/video]
Another MkIII
697
Chicago
My understanding is that most engines are built this way.
-AM3
Another MkIII
697
Chicago
IJ.;1850416 said:
LMAO very few if any car engines are "Big Bang" (2 cylinders fire at the same time) only ones I've ever seen use this were the GP bikes when they went 4 stroke.
That's what I thought, but being young, I haven't seen everything.
-AM3
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Technically, this does depend of your 7M is a GE or GTE.
The GE uses a distributor, so there is no waste spark, it's a straightforward 1-5-3-6-2-4 pattern.
The GTE uses the distributorless ignition, and fires in pairs. Still, the fact that the cams can be swapped indicates that the firing order is exactly the same. So each cylinder will have the plug fire as it approaches TDC. Of each pair, 1 will be at the end of compression, and 1 will be at the end of exhaust.
te72
6,624
9
WHYoming
I did a little more research on this last night, some rather interesting reading here:
http://www.epi-eng.com/piston_engine_technology/torsional_excitation_from_piston_engines.htm
Anyway, thanks for clearing that up guys. It would seem that odd firing engines are uncommon, and the even/odd fire thing has more to do with timing than how I initially understood it.
Now for the fun hypothetical question: How would an inline 6 behave if the cylinders were fired two at a time? I would think the torque output would be pretty awesome, but when 1/6 fired, you would put a lot of stress on the center of the crank...
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Yeah, I was wondering why what you were getting at had to do with even/odd firing. I own an odd firing engine btw. The first generation PRV 6 is such an animal. It comes from it being a V8 with two cylinders loped off. You can tell distributor equipped odd firing engines by the uneven plug wire spacing on the cap.
te72
6,624
9
WHYoming
Sorry if it was unclear in how I worded the first post. I've heard of a few of those V6 engines. It seems that they might be the only "traditional" engine layouts that are odd firing. Seem like they're prone to very high levels of torque, but not very smooth running, from what I was reading.
How do you like it?
Asterix
Lurker of Power
Vienna, VA
Reminds me of the V4 in the Sonett III I owned many years ago... It had a balance shaft, though it ran at crank speed. Not a bad little engine.
