Supra cranks but wont start
Clied
Wangan Supra
Jun 8, 2006
367
NorCal
This morning as I was heading out to class I got in to the Supra and tried to start it up as usually, only this time it would'nt run. It cranks but thats all it will do.
Any suggestions?:icon_bigg
I tried jump starting it already.
Clied
Wangan Supra
Jun 8, 2006
367
NorCal
Ok I just tried pulling the EFI fuse and it did not work.
How would I test if the fuel pump is working? Would I have to remove the gas tank?
Also if it matter, my car was running great yesturday and this is the first problem I've ever had with it.
8,900
Pulling the EFI fuse does not fix cars. It clears fuel trim, which you can do on your own, clears stores diagnostic trouble codes (DTC's), and that is about it. If JJ has anything to add to that, then fine. Pull your EFI fuse after fixing, and after pulling codes. You do that to make sure it isn't an old code.
Based on many of these threads on this forum, the suggestion of pulling codes and looking for 14, and wiggling the CPS wires is a good place to start. So those were good suggestions.
Clied
Wangan Supra
Jun 8, 2006
367
NorCal
CODE 12 RPM Signal
Diagnosis
No "NE" or "G" signal to ECU within 2 seconds after engine has been cranked.
Trouble Area
Distributor, or CPS, circuit
Distributor or CPS
Starter signal circuit
ECU
I dont know what any of this means though...:1zhelp:
Clied
Wangan Supra
Jun 8, 2006
367
NorCal
Heh ...You guys were right.:icon_bigg
Turns out it was the cps. I just tried wiggling the wires, cranked it and the Supra started right up.
Easy Fix:icon_bigg
dbsupra90
toonar
indiucky
good deal
you might want to go ahead and fix it right. it will keep happening if you dont, and always at the worst time.
you can either buy new clips and pins from toyota to replace it all, you can hardwire it bypassing the clips, or make your own clip.
you can take it apart and bend the clips so they make bettery contact. but ive found that to only work for so long as well.
lastly, before you take anything apart take note of the wire colors. they dont match up to each other.
