subframe bolts
callme676
27
nc
what is the size for the two bolts that bolt the back of the front crossmember to the frame?
and my fave pic of the interior
Satan
Tampa
You need to take a pic, but further back. I can't tell the orientation, or part in the pic. Remove some leaves first? The front subframe bolts on my 91, were either 17mm or 19mm. The rear subframe had a couple of different sizes. Maybe 17 or 19, and 14mm for the forward bolts.
callme676
27
nc
thanks for the info,i cant remove the leaves unfortunately bcuz im in nc and the car is in philly.im trying to figure out a way to transport the car,i think i might rent a tow dolly so if i do that i have to have it bolted properly(the car)
7EMPIRE
175
Raliegh
i have to tow it from philly to raleigh nc so i have to bolt the subframe if i use a tow dolly thats why i need the bolt size
Is the sub frame off the car? I cant tell anything from those pics.
Would still need to remove the drive shaft unless using a flat bed.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,265
60
Atlanta
I'm getting the impression that the pic shows the rear of the subframe hanging down- is that the only section that needs bolting up?
Just go to Toyota(or call) and let them look it up.
callme676
27
nc
yea that pic you drew up is right and yes there is no oil pan,which sucks but yea jus those two bolts basically
Well get everything bolted up, as it should be no matter what, and move it where you want(as long as the ds is removed for a dolley, flat dont matter)
If it's missing those bolts, I'm betting it's missing more. Having a catastophic failure while towing it is going to wreck the car, probably your truck, and hopefully there aren't any people around you when it happens.
Do you only have photos to go off of or does the owner know what it's actually missing?
7EMPIRE
175
Raliegh
i bought the car from my cousin, so i know that other than the subframe bolts, its a complete car,i have all the peices i need in the trunk.plus there was an extra engine with cracked block,i stripped all the parts off that and filled the trunk but being that i only paid a ps3 and 300$, and the interior is almost mint and the car and motor had 128,000 miles on it i cant lose on my investment plus its my dream car.
[/IMG].
[/IMG].
[/IMG].
