stuttering
jon_570
maryland
my 87 turbo 5-speed supra has a kind of stuttering problem.. idk if this is what all of them do but ive been told it shouldnt
if my cars warmed up and its idling which is around 650 750 and i hit the as down it bogs just real quick then picks up.. what could cause it?? dirty injector?
skipbarber
2008 Grassroots Challenge
Mar 26, 2008
134
Rockville-ish, Maryland
perhaps an air metering issue. if it's bogging, it's throwing in more fuel because it's compensating for more air. So something must be tricking it to think that more air is going into the motor than there actually is. id start by checking all the hoses at the AFM and checking the accordian hose for leaks.
jon_570
maryland
accordian is is semi new.. old one was cracking and i baught one from a member here.. the MAF is a little dirty. i can use MAF spray cleaner right?
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
if you think its your injectors it might not be a bad idea to send them out to get cleaned and tested since well.. theyve probably been running in there a while hehe
sogi99
115
Elk Grove, CA
check for codes and then check for vacuum leak and put some lucas fuel injector cleaner in the gas tank hopefully that helps solve the problem
