Stumped with weird electrical issue, gauge lights and climate control lights.
89whitepkg
I hate rust !
Mar 7, 2006
121
Lexington, KY
So, I Just started having a wired issue this morning that I'm really hoping one of you guys can shine some light on.
I get in the car this morning to drive to work, but I find that I have now gauge lights or lights on my climate control unit. I drive to work and check all the fuses.All fuses are fine.
I did notice that when I turn the headlights or the parking lights on both the climate control and gauge both flashed on for just a brief second and then back off?!?
Any ideas??
Thanks guys
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
78
Atlanta
suprasick;1754216 said:
just throwing it out there.... have you checked your dimmer switch?
What he said. Bad dimmer = no dash/ climate control lights.
I believe you can test the theory by bypassin the dimmer control.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
To bypass jumper the white wire with green stripe to the white wire with the black stripe... They're two of the three wires running to the dimmer; The third is green, you don't need to do anything with it.
