I have a question for anyone who may know the answer. In the process of fitting up my LS6/T56 setup I have needed to remove both OEM transmission mounts (frame side). To do that I simply drilled out the spot welds. I also removed the bracket that holds the handbrake lever using the same method. So now I have weakened the transmission tunnel.
I removed a good amount of material from the "c-channel" that the front of the seat rails bolt to. Basically the c-channel no longer exists on top of the transmission tunnel.
Basically, I know I have weakened the unibody. The question is, what is the most feasable way to regain that lost strength. And is it even something to worry about?
