Hi, i have a strange idle problem.
Here is a small description of my car to help :
Stock internal 7mgte (except of a MHG)
60-1 CT26
560cc/lexus maf +255 pump and AFPR
Apexi Neo
2.5 inch intercooler
Greddy bov
water/meth kit
First of all, does 625 rpm when hot is ok or too low? I would prefer it in the 700 range...
Ok, here is the description of the problem. When the car is idling and you quickly press the pedal or rapidly move the throttle wire. The engine will mostly die when dropping down to idle rpm, or at the least, will have some difficulty to idle correctly for a few second.
If you move the throttle wire super super fast, just a super quick shot of gas, the engine will not rev higher, it will simply ''buck''...
Sometimes, but to too often, the engine will die after pressing the clutch and the brake pedal to a quick stop.
An the last explanation, when i'm cruising to a certain level, pushing the gas pedal to 5 or 10% max just to maintain the speed, the engine can start to ''bug'', acting like there were no more gas or air going to it... Making me removing my feet from the gas pedal, or simply giving it more...
I dont know if all i described are related to 1 problem or not...
This problem is certainly not easy to describe, almost impossible to search...+English is not my first language so there could be some grammar error making me more difficult to read.ç
60-1 CT26
Apexi Neo
Greddy bov
water/meth kit
