When I start my car, most of the time the idle is normal around 800rpm, but every now and then I start it and the idle skyrockets to 2500rpm and I am stuck turning the car off and on until I get the normal idle speed of 800rpm. It has a tendency to do this after I've already driven x amount of idles to point B and start my car to return home to point A which is usually a bad situation because I am not in a place to look under the hood and see if the throttle is getting stuck open or what. Usually when I get the 2500rpm idle and I stop and restart my car to get the normal idle, my car will lose power under throttle until 3000-3500rpm. I've checked the ACIS and it is moving freely and is not gummed up and am wondering what else may be the problem.
