hi all i was attempting to turn up the boost with my greddy profec b spec2 my old ct26 turbo held 12psi no prob i got a new wastegate with my 57 trim ct-26 and could only boost over 6psi for a second and then it would settle at 6psi, was wondering if i could simply tighten the wastegate actuator rod to hold my higher boost levels (eventually 15psi hopefully) can it be adjusted to hold this much without causing problems opening the wastegate?
