Stock tranny whp?
supramacist
1,501
The Grassy Knole
Man you didn't search propperly or you would have found something because those of us that have been here for a while know how often that is brought up.
Try Harder.
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
Fuzz420 said:
torque should be a bigger concern
True
As for Hp, I read somewhere that for the W58 is was around 400 hp for a good one, less for older worn out ones.
And for the r154, the sky was pretty much the limit. Thats a quote from where I read so dont yell at me lol
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
W58, depending on condition can be blown up with stock torque levels.
The R154, a good one, can take some impressive numbers.
The A34x automatic can take around 400-450whp with alot of tranny coolers.
Ma70.Ent
1,871
NJ
One of the more common causes of a340e's failing is heat, so get a transmission cooler if you're going to have a lot of power on it.
Note: The A340E on the turbo is different from the N/A. (# of clutch packs)
8,900
I got to say, you are normally better than this. 'Cause that statement was bullshit.
Or at least how you are presenting it. The belief that the W58 is a weak sister, and the R154 can do no wrong, is wrong. Look at the R154 threads. One has ruined several just by using too strong of a clutch.
supraman24
Trooper
Apr 12, 2007
20
Prattville, Alabama
I was pushing around 310whp and about 330lbs/ft on my W58, but then my clutch went out, so...not sure if I wanna put anymore power to the W58. I'll definately go w/ the R154 if/when I get my Supra running again!
turbo4toy
208
Los Angeles
Will a 89' turbo auto tranny directly swap into a 89' Cressedia? I happen to have a left over tranny from a turbo car and was just wondering if it would work. Or do I need a NA auto tranny?
