can someone help me locate the tach wire under the dash. i need to send my rpm signal from an aftermarket coil pack to my stock tachometer, hoping i dont have to remove the gauge cluster just to tap in. 92t so newer style harness colors.
does someone know if the stock tach is 200volt input or 12volt input? or possible 5v? looks like 200v as the signal comes from the ignitor and not the ecu?
