So I looked at the tsrm and it said that it means the turbo pressure sensor is failing but when I turn the key the gauge goes to zero, then when I start the car it drops all the way back... So the questions are:
Could it be a vacuum leak also or should I just go ahead and replace it or maybe just go to an aftermarket one and bypass it?
And if I do go aftermarket and completely remove the stock one if the ECU would throw codes or throw the car into limp mode?
-V
-V
