Stock 1jz dyno
eps
usa
250whp and 260wtq
Not bad for just a gutted cat and 3” catback.
It’s not real rich like I expected it to be, it’s actually quite lean in the lower RPMs.
Also the guy who was doing the dyno said it would not rev to 7k. :dunno:
SupraMario
I think it was the google
7
The Farm
nice, and he said it wont go to 7 grand? i thought the redline was 7 grand, and toyota put it at 6.5 as a precaution?
drunk_medic
7Ms are for Cressidas
Woodstock, GA
If there is a limiter, you need to defeat it; I've heard of Aussies and Japanese taking the stock 1JZ to 8k, and with a built valvetrain, 9-10k is not out of the question.
OneJoeZee
Retired Post Whore
aboard the Argama
ive run my ca rup to 8k a few times... dont think ill be doing that too often though...
Dew511
Q-boro, NY
Good numbers. I dynoed mine a couple months ago... stockish. Only had a intake and catback exhaust. Did 267whp and I remember the torque pushing 12lbs of boost. The thing is that it was 94 degrees at the time and over 70% humidity. So the tech guy was like maybe 300 to the wheels. Sounds Good. Haven't felt it yet tho! My speed cut kept cutting in at 125mph. How can I bypass that? O... I hit the rev limiter like exactly at 7k.
I
itr206
Guest
my limiter is at 7200 off the top of my head. I never had a problem getting it up that high
Boostedstr8six
I have better SA than you
Near Columbia, the river
The graph shows your TQ and HP numbers intersecting at 4750-4800rpm....when those numbers will ALWAYS be equal at 5252 rpm, no?
Good numbers for stock too, I think. I'm a 7M head so I'm not sure. :D
OneJoeZee
Retired Post Whore
aboard the Argama
youre right, that is strange... i thought it was 5252 always as well... :aigo:
eps
usa
It is 5252rpm but the graph is not setup with equal HP and TQ readings. For example, at the 150hp mark its 200 for torque.
mattjk
Permanent Ban
May 18, 2006
1,973
Huntington Beach
i just dyno'd my 1jz and am a bit disappointed.
267.18rwhp and 269.80ftlbs torque.
this was in 4th gear, 10.1:1 a/f, and .9kg boost
My mods are 3" downpipe and catback, and k&n type airfilter.
I suspect it is low because I'm running very rich.
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
Well this is the second dyno on a dynojet : 285rwhp/291 torque
Mods currently : 2jz map , 2jz 550, 3inch catback , 14psi boost (kept hitting cut around 6500 for some reason), SAFc-II tuned to 11.5 I believe.
I don't have a y-pipe nor a downpipe.
OneJoeZee
Retired Post Whore
aboard the Argama
mattjk said:
ok I feel better then.. I was pretty depressed, although the car feels really good.
that's what matters. that just means the car feels really good at a lower power than you thought. so imagine what it will be like when you get it up in the 280-300 range. :) you could ride in my car and see how it feels. :) I kept up with jose and mikeT and they did like 310 and 350. :)
suprastanger507mgte
Hayward , Ca
I agree with Joe. It all matters how the car feels when driving it. I had a little go with a 05 M3 today. From the light, I left him standing when it turned green. He kept chasing me down the freeway but was not able to catch up, and I kept pulling away. And all this with me not even seeing 300rwhp on the two dyno sessions I have been to. I think the guy looked pretty embarrased.. lol , in the BMW as I handled him in and out of traffic pretty well too.. lol
Definitley made my lunch break worthwhile.
I will try and locate my dyno numbers when I first got it on the dyno.
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
fix the af and you'll be very close to 300
EPS i believe your problem is that you may have a soraer ECU.
Are you sure you have a JZA70 ECU? Could it be modified, maybe the previous owner had a 1.5JZ.
OneJoeZee
Retired Post Whore
aboard the Argama
yep, moe. :] don't get too caught up in numbers, matt.:) different dynos read differently on different days and in different weather. you could go somewhere else tomorrow and put down 280-290 for all you know.
dynos are a tool best used for baselines and seeing the differences in mods or changes you've done.
suprastanger507mgte
Hayward , Ca
Basic Mods :
AVCR Boost controller - set @ OFF , Set at 1.05 abr , Set @ 1.15 ( starts hitting cut)
SAFC-II
Cat back 3 inch exhaust with test pipe.
2J Map Sensor
2J 550 INjectors
K&N Filter
Stock MKIII pump.
The AVCR was fine tuned first to hold boost better and then SAFC was tuned.
Couldn't up the power much due to boost cut but I was really there to get my A/F right. I stayed conservative for the first tune. Wanted to make sure all bugs were gone before doing anything aggressive.
I need a boost cut controller before I start cranking the boost up for more power.
I also think my stock downpipe is jst not cutting it.
Power/Torque made : 257hp / 252lbs/ft
Car runs and drives so smooth now that its tuned. No more smoky tail pipes :)
