Still no fire
JStoked
646
Edmond, Oklahoma, United States
ok checked all fuses and jumped efi relay still no check engine light and replaced builb. so pulled key ignition wires witch were all hacket and slots 5 and 7 are making contact when in lock possion is this norm
I6Boost
182
My Supra
Idk about the whole ignition aspect but
are your lights working? dash? windows? etc?
If so when you turn your key to acc i believe can you hear
your fuel pump kick on?
Re-check all your grounds.
Dont go straight to ignition.
Most likley your last thing to go out
unless you've messed with it before.
mkiiichip
1,434
WI
Wrong. The pump does not run until there is an rpm signal, sent to the ecu.
To the OP, are you having a no crank or no start issue?
Do the dash lights come on with the key? Which ones come on?
Oct 11, 2005
3,821
26
Thousand Oaks, CA
Its pretty simple, you need 12V on the BAT ECU pin, and 12V on the IGSW ECU pin along with good grounds to E1, E01, E02 and you should have a working MIL light. Check those with a voltmeter and let us know what you find.
JStoked
646
all lights come on BUT the check engine
---------- Post added at 07:30 PM ---------- Previous post was at 07:29 PM ----------
ok i will try that thank you very much for the info will post what i find out
