Posted a while ago, still haven't been able to figure out the problem. I will try to describe the problem in different phases/combinations.
Cold start: Car runs at 13.2-13.7 while warming up, as soon as the thermostat opens, goes instantly full lean and starts bogging trying to shut off from very low idle.
Warmed up: Taking off from 1st will run full lean until about 2k rpm then it realizes "oh shit im running lean" and it corrects itself to either 14.7-15.3 OR runs rich at 12.0-12.5. Also, has random fits and sometimes fixes itself sometimes it doesn't.
Cruising: If I let off the throttle while in gear, and resume acceleration, will stay full lean forever unless i mash the pedal to the floor and it corrects itself. Same problem when switching gears.
Never goes full lean at all if I disconnect my o2 sensor, but then it will always run rich.
Mods:
evo9 560cc
walbro 255
egr delete
lex afm
Have tried: different afms, different tps, different iacv, new coolant temp sensor, new o2 sensor, timed correctly, no codes
my issue is VERY similar to this guys: http://www.celicasupra.com/forums/archive/index.php/t-69751.html
Unfortunately he gave up and parted it out, and I have also found 1 or 2 other cases with the same thing but never resolved. Fuck me right
Any input is appreciated.
Mods:
evo9 560cc
walbro 255
egr delete
lex afm
