Status on the Supra
SUPRASTEVE
Supra Maniak
Jun 13, 2007
504
So Cal
so we took it to a specialist for toyotas. Apparently the stupidest thing was broke on it. THe Air flow meter. I didn't bother checking it because i changed it. Apparently I bought it for an 89 turbo auto not a 5spd and so it blew out. So the specialist says. So any one in SO cal got one. I am really really tight on money so help a brotha out maybe we can work something out since I got a couple subs and a set of polished out sawblades.
SupaMan
Want The Boooooossttttttt
Oct 12, 2006
1,101
Cape Coral,Florida
i dont see how thats right.......me thinks the so called "specialist" is pulling your chain, from what i understand theyre the same regaurdless of transmissions. unless of course you bought a flapper n/a one. which im not even sure would plug up.
but if you wanna try it youd prolly get farther posting a WTB or WTT thread in the wanted section and saying in there about your subs and blades.
LilMissMkIII
That Aussie Chick
Aug 18, 2006
4,110
Aussie Land
As i said in Flaschat, i'll get pics of both the AFMs I have and pm them to you... Take the pics to him and tell him to shove it up his ass ;)
SUPRASTEVE
Supra Maniak
Jun 13, 2007
504
So Cal
No I didn't break it I ran the afm for about 3 years no problem. the car just kinda started bogging one day and it does that at any rpm and it seems like it gets worse every time i start the car. Its like some one cuts the gas on it or something and no one around here can physically come and help me.
LilMissMkIII
That Aussie Chick
Aug 18, 2006
4,110
Aussie Land
If you want some help to diagnose what's wrong...
List out in this thread what you have checked and ruled out, and try get a video.
SUPRASTEVE
Supra Maniak
Jun 13, 2007
504
So Cal
I've checked all my plugs, wires, coil packs, igniter and cps and tps and changed out my fuel filter, and checked all my ic hoses. They all check out. I tested the electrical with ohm meter and it set every thing fine. it also died b4 I timed it so i know its not my timing.ANYONE IN SOCAL ABLE TO HELP ME I CAN PAY YOU!
SUPRASTEVE
Supra Maniak
Jun 13, 2007
504
So Cal
got the fiing car back and guess what it runs worse than it did b4 I got a shit load of codes too and it won't even idle i will give you guys the codes in a bit. THIS SUCKS STUPID SPECIALIST FS UP MY CAR EVEN MORE PROBABLY SO I CAN BRING IT BACK WHAT AN ASSHOLE!!!!
SUPRASTEVE
Supra Maniak
Jun 13, 2007
504
So Cal
So i have code 24 intake air temp sensor signal thats a very new one and its probably unplugged by that crap tech, anyone know where the this sensor is cuz i don't. I got code 34 which is turbocharger boost pressure, which I am sure the AFM is dead. and code 51 which is pretty much the tps being off but thats ez.
SUPRASTEVE
Supra Maniak
Jun 13, 2007
504
So Cal
SUPRASTEVE
Supra Maniak
Jun 13, 2007
504
So Cal
Ahh I see all points to the air flow meter than. Hmmm I wonder why it blew out. the assmunch said it was because the numbers were off, and that it died because it wasn't a perfect match or something.
