starting problem
bigal0043
813
Plattsburgh,NY
www.mk3supra.net
now i was in a rush yesterday so i havent had time to mess around with it but here is what the supra was doing...
lately you would turn the key to the start position and you here a click and then nothing for a couple seconds then it turns over and starts...
well yesterday it just made the click noise and nothing..
im assuming it is my battery not having enough juice to turn over the engine.. the positive terminal is brand new and there is no corrosion there... there is power to everything and when you turn to start and it clicks like my radar resets and everything...
tonight im going to try to jump start it to make sure its the battery.. but im just seeing if anyone had any other ideas before hand
karmasupra
67
Macon, GA
I've been having the same problem. Each time I'll hold the key in the crank position until it fires up; sometimes 10 sec or more. It's worse in the winter. The guy at the local auto electrical shop checked it out and said the starter was going bad; just haven't took the time to swap it out. So check that first.
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
could be the starter, could be the battery, could be the power cable. Mine does it sparratically and i did a battery test and found out i have low electrolyte levels and sulfated plates. so yeah, i should replace that. I hope it stops when i do that
ariel4946
toyo maniaco
Jun 5, 2006
24
puerto rico
check for the starter solenoid contacts and if the problem persist instal a relay for give a good courrent to the starter ,i haven the same problem
MKIIINA
Destroyer of Turbos
Plano, TX
sounds likethe starter is going out there chief. had the same problem in my car and my bros when they started to go out. dont get an autozone one! either rebuild yours or go to a good electronics place and have them sell ya a new one.
Suprastic
727
Manitoba
i had the same problem with my car. I relpaced the battery, starter, cables, terminals, ans altenator, and still had the same problem. Everytime i replaced something it just prolonged the problem for a while. I installed a push button starter, and I have no problems anymore.
bigal0043
813
Plattsburgh,NY
www.mk3supra.net
first thing is going to check out the battery... i think it is that because i left it in the car in the winter... it was pretty dead when i went to start it when spring came.. i just charged it... and i think its just losing its charge time to go to autozone tomorrow to find out
CPT Furious
Now MAJ FURY!
KDOV
The starter isn't a lot of fun. The top bolt is a real PITA. If the EGR is removed, you will have an easier time with it.
johnathan1
Supra =
Aug 19, 2005
5,056
Why not autozone...that's what I have in my car and it's been fine for about 9 months now...
bigal0043
813
Plattsburgh,NY
www.mk3supra.net
well it is something with the starter.. i tried jumping it but still the same it just makes a click noise... do i need to jack up the car to get to the starter?? i really dont know where it is.. besides under the intake on the bell housing.. though i dont know where the bell housing is anyone got any pics of it
bigal0043
813
Plattsburgh,NY
www.mk3supra.net
alright took me 1.5 hours and a really really long extension but the starter is out.. i brought it to get tested and it works just fine.. so now i guess check the relay but you guess have any other ideas?
bigal0043
813
Plattsburgh,NY
www.mk3supra.net
alright update after putting the starter back in i noticed a plug hanging there... its the KS next to the starter :aigo:
so that is why i have been getting bad gas millege and the end of it looks pretty burnt up so to me it seems that the plug was touching the starter causing it to spark and not causing it to start? The really bad gas millege and weird starting all happened around the same time so i hope that is what it is
*edit* would you trust getting a KS off ebay? Also can i get the KS off with the manifold on?
bigal0043
813
Plattsburgh,NY
www.mk3supra.net
update again
got the starter back in everything hooked back in and it fired right up no click noise or anything...
so it was my knock sensor touching the starter causing it to short out..
now i just have to get me a new KS
