Starting Problem 87 Turbo Targa
Sonic
22
Calgary
Hello having a starting problem,
vehicle has
- new ignition coil
- new fuel pump
- new plugs / wires
- new alternator
- new starter
car turns over but wont start , sounds like no fuel but i check the fueses and all are good
car was running last year, did have igniter changed and ran again, but gave same symptoms as first
time (starts after two or three trys) then vehicle wouldnt start 3 weeks after igniter changed , igniter was used.
does anyone have any sugesstions
can get video up soon if need be
any suggestions or advice would help
thanks peter
james_9876
Rehabilitation time...
Aug 1, 2007
183
Spartanburg, SC
Yeah.... I'm at the end of my build and I had the same problem.
Like he said, white and brown wires are the ECU's ground wires and need to be grounded (not hooked to the started bolt ). Make sure you ground to the ignition coils is good. Make sure you have no fuel leaks.
Sonic
22
Calgary
yeah tac dosent move, and the grounds look to be fine not corroded but just to be sure i will take them off and sand them down to get clear conection,
do you guys think the problem might be the igniter and or ecu
cause i have both those parts comming
just cleaned grounds under intake and ground for battery , gunnna ty again when i get those parts in
Atsushi7mgte
203
Oahu, Hawaii
i had this exact same problem!
and i have a 87 turbo targa also lol
if your car is white like mine that would be really trippy
well anyways to make a long story short...
i had no spark in cylinders 1 and 6
so i bought a new ignition coil and spark plug cables
turns out the problem for mine was one of the wires going into one of the plugs had backed itself out and wasnt making good connection
check all your plugs and the wires going into them.
wasted like 200 dollars...
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
sounds like a cps wiring problem.
check out your cps wires, and wiggle them then start the car,
if your tach dont bounce your ecu isn't seeing an cam position or so to say crank position. and doesn't know the motor is spinning stupid i know your cranking it, but it doesn't fire the injectors. or spark plugs for that matter.
Sonic
22
Calgary
checked cps wiring and seemed ok but i will try again , as for the coil it seems brand new and the previous owner said he changed it, so could it be just the plug wires ????
illegal88
31
Rockford, MI
Its the CPS!!! if your tach doesnt move the your ecu isnt seeing the engine turn over...
zachm611
Beauty In Disguise
Apr 15, 2006
544
new mexico
try messing with the wiring first, dont waste money on all new parts when it could be something simple as a few wires, sometimes the wires at the plugs get corroded, try jiggling the wires, also try unplugging then plugging it back in, my wires were so brittle 2 of them broke off so i ended up having to hard wire it and now it starts fine.
Sonic
22
Calgary
ok we hard wired the cps, and still tac dosent bounce and dosent start should i replace it the cps that is
Sonic
22
Calgary
ok guys i need to get this thing running, if the cps dont work , and the ignition coil, then what can i do with anything just to get it runnin please guys any suggetions
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
You should of tested you're CPS to start with. If you don't know how to test it, you could take it out and have a shop test it. And of course you could always search to find out how to test it. IMO its not hard... and there are devices that good shops have to test it the right way, so really it would be best to test it there.
Sonic
22
Calgary
well sorry dont have time as i am a full time student and hold two jobs as a part time carpenter and hardwood installer , o and i forgot plus a wedding in maui which i am a best man in so i would have gotten it tested but i could save the time and might aswell replace the part prematurely before it breaks
when the part is only 50 or so dollars , so positively please keep the comments to your selves if not here to help
thanks
Sonic
22
Calgary
ok cps was bad cause new one is bouncing, but vechile wont start dont think im gettin spark , i tested 1 6 5 and none gave me spark , so should i just replace the entire coil pack or do can you guys think of anything else for me to check
DayummiMFLyy
United States Marine
Aug 30, 2007
Bronx New York
well i have the same exact problem....
87, turbo, targa, and yes its WHITE!
i checked the ground wires... seem fine...
i crank and i smell a bit of fuel... cant see where its coming from though..
im actually here looking for the same answers...
my CPS is not wired because it was tapped into and now the wires do not match color... im kind of in a dead end situation because
1)my CPS isnt wired
2)i smell a fuel leak
3)i have no spark on the coil pack
so im pretty much stuck i guess i gotta take this to an electrician huh ??
