Starter Issues FAQ
TurboWarrior
Canada
This is my write-up, I was hoping to get this in the faq section. Correct me on anything if i'm wrong guys.
If you have a (click) when you attempt to start the car emanating from the starter motor/solenoid that is what this writeup is about. If the motor does not even make a sound when you turn the key you may have other issues.
This is a list of what is wrong most of the time
1. The contacts in the back of the starter are worn out. Take off the back plate of the actuator unit by removing 3 bolts. Remove the plunger. If you see heavy wear on the 2 contacts that the plunger comes into contact with they need replacement.
Jeff Lange
The Toyota kits come with more than just the contacts; they include the bolts, washers, etc.
1986.5-90 Starter Contact Kits:
28226-72080 Battery Side Terminal Kit
28226-72010 Motor Side Terminal Kit
1991-92 Starter Contact Kits (Same as the JZA70 1JZ-GTE 1.4KW Kits):
28226-76070 Battery Side Terminal Kit
28226-74070 Motor Side Terminal Kit.
If you notice that the contacts aren't overly worn and the contact part of the plunger is ok then there is another problem.
2. You have a bad battery or your alternator is bad and the battery is not getting a full charge. Get the battery tested or try swapping out for another. If the car still doesn't start you have another problem. Clean your battery terminals always if they look rough with a heavy wire pipe cleaner or a longer bristled wire brush. If necessary replace the terminals or wires if they are bad.
By bad I mean cuts in the shielding, weakness in the wires. A weak battery + weak wiring + old starter, it all compounds the problem. Weak wiring sometimes you can’t do anything about but if your battery, alternator, terminals, obvious grounds are all good and you know they are it narrows the problem. Maybe you replace your starter and the problem goes away, but comes back on you after a length of time. That’s other weaknesses starting to show and replacing the starter only band-aided the problem until the starter came under some wear.
Assuming the battery and charge is ok
3. You have bad or worn wiring, usually a single bad wire. Try jumping the car with another vehicle or a booster pack. If the car starts when it is being boosted (which is usually at 14v) this is probably it. The extra voltage and current available compensates for the bad wire. The single wire spade terminal (the small one) at the back of the starter should be the culprit. Try holding a wire to that terminal and touching the end of the wire on the + side of the battery. If it starts to crank that is your problem!
Either run a switch from the + lead to the cabin and from the switch back to the starter. Or replace the wire. Run your own wire from the back of the starter into the cabin and splice/connect it to the ignition switch. The exact color on the wire on both ends I am not sure of yet. I think it’s slightly different too with an automatic transmission. Either way if you do the test and connect a wire from the spade terminal on the back of the starter and it cranks, this is your problem area.
Remember that when you use this test method or mount a switch it is bypassing the safety features of the car for starting. If it is in gear the car will fly forward. Make sure the vehicle is in neutral or park.
Less common causes are the ignition switch itself, Starter relay, Neutral start safety switch itself (auto), or clutch start safety switch (Manual Trans.)
The order you should test in should be easiest to most difficult.
1. battery and charging system
2. Cleaning the battery terminals and checking the obvious grounds and leads for wear.
3. Jumping the starter solenoid
4. Checking the contacts
1 and 2 are simple. 3 can be simple with thin arms like me, if not you may have to remove some parts. 4 the starter needs to be removed. Based on your gut instinct you may change the order. Hey its a good way to learn.
If your starter clicks only when your battery is a bit low this could also be your contacts or any of the above I mentioned. The mkiii is getting old. Everything is wearing out. Hope this helps!
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
good work... i outlined it on the other STarter thread on SF but good working cross-posting info here.
i can confirm non-contact related issues. i went thru 3 different starters and 2 sets of contacts before i finally bought wire, connectors and a relay. now my starter works flawlessly.
heres my post. if your contacts are fine, do what i say:
flubyux2 on SF.com said:
well, i ended up having the same problem a few months ago too.
i thought my starter was just old. i took a spare starter and had the contacts replaced. then i crawled under my hot car and swapped the starters after alot of cussing. doing the swap w/ the pre-91 starters is a HUGE PITA. fuck nuts and bolts! so, new starter on and nothing but Clicking. it wouldnt crank the car on its own. i put the other starter back on w/ the best of 4 used contacts thinking the new contacts were faulty. i had no improvement. so i put the starter w/ the NEW contacts back on and got a ride to autozone.
i picked up a small spool of 12awg primary wire, heat shring female spade connectors and some tape. i used the stock Starter solenoid wire and extended it to trigger the relay. i grounded the other side of the relay coil. im pulling 12v from my alternator cable which is connected directly to my Battery (relocation kit). the other side of the relay runs to the starter and i soldered/taped the factory starter solenoid connector for plug-and-play use.
SUCCESS! all my previous starter issues went away.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
I also did the extra relay mod and have no problems, this is safer and a million times easier than running a new wire, the switches inside the ignition arent meant to carry a whole lot of current so the relay method really helps improve the performance of everything
TurboWarrior
Canada
thanks supra1
fluby same as me you found out the hard way. i took the damn starter out 4 times total too. I ran a switch to the cabin. and the switch melted internally or something and fused. So while my dad was driving the car and the starter cranked until it burnt out. It's insides melted. Luckily i had a spare. After i finally figured it out it still cost me a starter.
CyFi I never heard of that mod...any links? or what to get.
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
i think i recall seeing a TSB for the mkiv regarding the starter click issue and it said to add an extra relay.
basically it uses the stock starter solenoid wire to trigger another relay. then the new relay pulls power from the battery or the alternator post to give a full voltage signal to the starter solenoid. its not a large amount of current, its just to trigger the starter.
the stock starter solenoid wire is very small and can experience a voltage drop. if you have insufficient voltage coming thru the vehicle harness and to the starter solenoid, the plunger will Move but not fully extend. if it does NOT fully extend, youll hear the gear contact the flywheel (thats the click) but the contacts will NOT engage. since the plunger does not full extend due to low voltage, the contacts dont engage and the starter motor never turns.
the solution is to get PROPER voltage to this starter solenoid/bendix so it fully extends. this way, itll engage the contacts on the plunger and the starter motor will turn. the way to do this, is add a standard bosch 30amp relay.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
TurboWarrior said:
thanks supra1
picture borrowed from "isnms" on the supraforums.
You want to add a relat just like this.
http://i80.photobucket.com/albums/j187/isnms/Supra/SupplementalStarterRelay.jpg
I reccomend you make the wire 12 gauge or thicker.
If you buy a regular bosche style relay from radioshack or something and buy these http://www.radioshack.com/product/i...&cp=2032058.2032231.2032283&parentPage=family
(you might need two packs) the blue starter wire and those female adapters actually slide strait onto the relay posts and the starter spade perfectly. All you do is crimp them onto the wire and slide them on. No more problems!:naughty:
Link to the original thread: http://supraforums.com/forum/showthread.php?t=124724
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
well what i did was cut the starter solenoid connector off with 2" of wire on it. i extended the solenoid wire coming out of the harness and added a female spade connector with heat shrink insulation on it. then i extended the starter solenoid connector pig tail and added a heat-shrink insulated female spade connector to the other end. one end plugs into the relay, the factory starter solenoid wire plugs right into the starter, with a locking tab and everything.
i suggest you do it my way... since its better.
