standalone fuel?
joeytvr
112
Louisiana
If I read right some where you can actually run injectors straight from piggyback. If so can we get around factory rev limiter like this?
no you cannot run injectors off a piggy back. piggy back will only modify the input signals the ecu uses to adjust fuel.
You need a standalone ecu with injector drivers to run injectors and at that point you might as well control ignition as well.
Zach
ECUMaster USA
Apr 6, 2005
375
TX
The DET3 is capable of driving up to 8 injectors directly (up to 4 per output channel). Most customers just use the DET3 to modify the MAF or MAP sensor signal, as you have to start from scratch building a fuel map when using the DET3 in "fuel implant" mode.
If your factory rev limiter is fuel only, then yes, you should be able to raise the rev limit when using the DET3 in fuel implant mode.
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
There were some old school piggy back systems, I believe HKS was one which had 1-2 injectors placed on the '3000' crossover pipe before the throttle body. Not the most efficient method but it has been done, they are quite rare to find now.
An a more important note the injectors have nothing to do with the rev limit.......................:/
Zach
ECUMaster USA
Apr 6, 2005
375
TX
Some factory ECUs impose the rev limit by cutting fuel, not ignition. In that case, driving the injectors from a piggyback would allow you to raise your rev limit. So yes, the signal to the injectors can be related to your rev limit.
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
Correct some do but the A70 ecu is not one of them.
It's also not a very safe method especially on a turbo application as there is potential to induce a lean condition.
