st swaybar question
C
cnewingham
Guest
is there a certain way it should be installed or will it only install one way? I pulled mine out and then put it back in but not sure if it the right was as the angle on the ends would be reversed if flipped around.
thanks in advance
pb92supraturbo
FTG & the IRL!
Aug 20, 2005
172
Garage, under Supra
I ran into the same issue and couldn't find any reference in the service manual. I removed the rear swaybar for an upgrade and couldn't remember the orientation. I ended up installing the rear sway bar with a bend allowing for axle clearance. I haven't had any clearance or handling issues. HTH . . .
don't have ST swaybars, but whiteline adjustables..
this is how they're supposed to be installed (ignore the shit exhaust)
asshate previous owner cut right before the resonator, used crush bent mild steel piping with a glasspack and two of those ricer upturned tips that stuck out like 6" from my bumper...
can't afford a cat-back yet, but I did hack off the tips and put a cheap wal-mart tip on there to look halfway respectable...
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
lol you will know if there installed upside down ti will smack into you frame when you hit bump reson being si my buddie did this so funny
NashMan
Aug 5, 2005
4,940
17
Victoria BC
yup but you will know it's upside down when you go for your frist drive lol
clunk clunk lol dude did you put that thing in right yes umm no it's up side down can it even fit that way ummm i guess soo but back to the bat cave
nanananananananana nananana a a bat man
