SSQV Flange Dimensions - Please help!
87witmoreboost
Officially HKS'd
Aug 27, 2007
323
New Hampshire
I need some info on the SSQV flange and a google search didn't help.
I am going to be installing a set of cooleeze pipes. They have the SSQV flange, but I need to plumb my Bosch 110. I want to make a flange that will utilize the seal and c-clip for a constraint, and output a fitting for 1" diameter hose.
I will need to make this on a lathe, but I cannot find any dimensions on it. So, I need someone to measure the flange that is on the bottom of the BOV itself. I need to know the diamater of the foot that gets c-clipped in. That along with the thickness should be enough for me to make what I need.
Even the ID on the female flange that is on the piping would be a help.
If I had the pipes already, I could measure off of that, but they aren't in yet. I want to make this today while I have access to the lathe at work.
Thanks.
87witmoreboost
Officially HKS'd
Aug 27, 2007
323
New Hampshire
Here are pics. I made what I could today and I will turn it down to a more specific dimension when I get some numbers.
Current diameter:2.950"
Thickness: 0.200"[/B]
SWD Fredester 3
674
baltimore maryland
Bottom of the HKS BOV is 2 3/16 " - 1/64" very close to 3/16 but to be safe
deduct 1/64"
Flat side of male flange in front is 13/16" wide
Thickness is 1/8" @ edge w/ a slight taper up to center
Female OD 2 9/16"
Female ID 2 3/16"
Female depth 5/16"
Hole to pipe 1 3/8"
Hope this helps, good luck.
Cordially, Fred
87witmoreboost
Officially HKS'd
Aug 27, 2007
323
New Hampshire
deduct 1/64"
Female OD 2 9/16"
Female ID 2 3/16"
Female depth 5/16"
Hole to pipe 1 3/8"
Cordially, Fred
Fred, you are the MAN.
Exactly what I needed, nothing less.
On with the turning, pics to follow.
87witmoreboost
Officially HKS'd
Aug 27, 2007
323
New Hampshire
Here are final pics. Very easy to make if anyone has access to a lathe and needs to flange a set of pipes with an SSQV female to feed a Bosch, stocker, Turbo XS recirc, etc.
