Squirting Noise seems to come from center of dash/Fire wall.. What is it?
Turbo Habanero
4,229
Tucson,AZ
So im getting a squirting noise coming from the dash when i accelerate or rev motor seems to happen when oil pressure rises? Oil squirters....?
Is this a problem or something to worry about ? whats the cause..?
doesn't do it all the time or atleast i dont notice it 24/7..
Turbo Habanero
4,229
Tucson,AZ
mecevans;1711217 said:
Air in the heater core.
Isn't that i sign of a BHG..
Most people said its more of a girgle noise then a squirt thats why i thought my nosie could be different.
my heater control valve is broken and i just have the hose on the back of the head by passing so the Valve isnt hooked up.
My head gasket is the stock toyota gasket with arp's at 90 ft lbs only about 2000k miles....
Backlash2032
1,823
Nebraska
WHY does everyone automatically jump to bhg when theres air in the system or coolant loss or overheating?
All that waterfall means is that theres air in the system. Burp it. If it comes back you could have a pinhole leak somewhere..
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Pressure test the cooling system and check for leaks (don't forget to check the floor inside the car for coolant which could be a leaking heater core), don't forget to test the cap while you are at it. Does it have a 50/50 mix of antifreeze/water?
Turbo Habanero
4,229
Tucson,AZ
ok so i fixed coolant line that runs to to the turbo it was split. (J shaped hose) car still hasnt overheated at all. nor does coolant seem to be dissapearing. if i make sure to squeez the upper radiator hose and stuff when i take off cap it doesnt ever make the noise seems to have gone away at this point. and i was running pre mixed 50/50 prestone anitfreeze.(untill tonight when i changed that hose and lost alot of coolant and just toped it off with water for now)
---------- Post added at 11:47 PM ---------- Previous post was at 11:46 PM ----------
Dylan JZ;1712552 said:
Because the majority of them own 7Ms?
J/K..
lol yeah im kinda of a pernoid supra owner smells sounds always think its gonna blow up on me. and i just did a head gasket job ARP's at 90 ft lbs...
