i have a 86.5 supra and when i am decelarating around like 20 mph and lower a kind of high pitched squeal comes from the manual transmission i believe .
any ideas on what it is?
thank you
thank you
modmonster2008;1582866 said:can you try to post a video of the sound?
edit: does it go away when you depress the clutch pedal?
Vrank!!!;1583022 said:What's the center bearing look like on your driveshaft?
droopdude11;1582785 said:i have a 86.5 supra and when i am decelarating around like 20 mph and lower a kind of high pitched squeal comes from the manual transmission i believe .
thank you
Nick M;1583106 said:To not be effected when the transmission is loaded or unloaded would suggest the rear output. To have noise when decelerating and torque is on the rear output helps push that thought. It needs to be looked at. As well as brake squeal.
