springs
Red '88T
84
Arizona
DSGsupra89;989203 said:
anyone have a pic of there car with them on are the good
Here you go... I just put this suspension setup for sale - coincidence?
turbojuiced
343
San Diego/Fairfield
well i think you see from the pic that it gets the car pretty low. And they are springs not a full coil over suspension. All they do is lower the center of gravity and obviously a more stronger spring in the first place. You will see the car more stable from the lower center of gravity and stiffer springs. But you wont notice a night and day difference because its not coil overs but you will notice a subtle difference.
8,900
Actually, it is a coil over suspension. From the factory. Buying the pieces seperate or together does not change the type of suspension you have. MA70's have SLA coilovers. Or double wishbone as Toyota wants to call it, instead of SLA.
turbojuiced
343
San Diego/Fairfield
^I was referring to the tokicos that its not a aftermarket coil over setup. And the factory suspension is limited to the amount of adjustments possible. This is why people people use aftermarket coil over setups to have those ajustments that the factory suspension lacks.
Ma70.Ent
1,871
NJ
* Stock MKIII
* Front: 461 lb/in
* Rear: 215 lb/in
* Drop: 0
* Tokico
* Front: 395 lb/in
* Rear: 198 lb/in
* Drop: 1"
DegreE
500
Memphis & Miami
I was unaware that Tokico had springs.
I'm sitting on Tokico Blue struts and Ehibach springs. It lowered the car about .5 inch. I'm not happy. I want more drop. I still have about 2 inches between tire and fender.
8,900
It isn't your fault you the internet gets polluted with bad terminology and tech info in the automotive world. So no problem.
http://www.supramania.com/forums/showthread.php?t=21315
