Spooling of the ct26
LordChase
Boost Lover
Dec 11, 2006
61
Greenwell Springs, LA
I am sure someone can answer this question pretty fast i have searched and cannot find it! Simply on a stock 7mgte when will the ct26 start to spool and when will it hit full boost. I have intake and a catback Start spool at 3.5-4k in first gear it seems a bit late so i want to compare. Rest of the gears will spool right before 3k rpms thanks! Any thoughts on spool time for an MBC at 10 psi?
RiyadYar
384
NY
the turbo would need a load to build boost which is why you dont build boost at neutral or alot (if any) in first gear
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
A CT26 should be fully lit by 3000rpm as peak torque arrives at 3200rpm. When it spools is fairly gear dependant I can build boost below 2000rpm in 4th and 5th gears.
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Ct-26 has a very fast spool. If you're having issues and you're not making peak before 3200 you may want to check for a leak or other issues. My '91 Auto has been the fastest Supra ( stock ) I have owned. I would spool fast.
Are you wondering where peak spool is at? Or do you have an issue?
