Speedometer problem
Remico
29
South Windsor, CT
hey my speedometer doestn work for some reason. i checked all the fuses and every other gauge works. could you tell me what is a possible problem and how i can fix it? thanks
8,898
The speedo is driven by a two piece cable. That cable is driven by the output shaft of the trans. The most likely reason is a problem with the cable. It might be broke at some point inside its cover.
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
Look next to the exhaust pipe. There is a small section a foot long or so.. Remove it and check the end that plugs into the tranny. If it is freyed then replace it.. If it has a single pin on the tranny side then it is probably the long section that connects to the guage cluster..
johnathan1
Supra =
Aug 19, 2005
5,056
I think that it is safe to say that part of your speedo cable is broken...It is three seperate pieces that run from the side of the transmission, behind the downpipe, then up and over the firewall to the speedo gauge...
SupraDerk
The Backseat Flyer
Sep 17, 2005
546
Tallahassee
Your speedo flux relay must be broken. They're like $10 from Toyota...
Haha, nah I'm just playin, I would start with the easiest to get to first. Check the drive gear (it's on the passenger side of the tranny, you should see the speedo cable going into the tranny...where it connects to it, that's the drive gear), if you can find a cheap one get it and replace your old one. If that doesn't fix it then change the cables, but the long cable is a PIA to switch...I did it 3 times when fixing my speedo...had a little mishap with my dremel and the long cable :naughty:
Superjustin13
Supra teacher 101
Apr 4, 2005
331
Idaho
3 you mean :)
and check the speedo commin out of your tranny 10 bucks say its broken, those are the ones that usually break
billspreston01
555
North Carolina
2 piece, 3 piece...whatever. The problem is the speedo cable :)
I have a auto-5spd swap and 3 piece speedo cable. Long piece, short 1' piece, then a small metal elbow piece, which screws onto the tranny
here's a question. Do the speedo cables have seals of any sort? When I fixed mine I swear a little seal type thing came out of the end, but my new one didn't have anything like that....hmmmmm
Superjustin13
Supra teacher 101
Apr 4, 2005
331
Idaho
supra90turbo said:
it is a two piece cable on 5spd's.
we're not all autos...
Eh
i Guess your right.
Cuz the auto uses a 90 Degree bend to hook onto the tranny
Im not auto just to let you know ><
and he didnt Say he was auto or 5 speed
soooooooooooooooooooooooooooooo
