speedo cable
jdub
Feb 10, 2006
10,730
Valley of the Sun
On a 7M, absolutely nothing but cause idle problems. It was removed on the '89+ TBs.
utsupraguy1010
utah
K so i just screwed it all the way back in pulled the efi fuse to clear the lights and then tried driving it and it still does not want to go over 2k rmps. I have codes 31 and 51 now. I do not have the knock sensor code anymore. My timing is advanced so that it would run back when the knock sensor light was on should i try adjusting the cps???
zachm611
Beauty In Disguise
Apr 15, 2006
544
new mexico
jdub;1191134 said:
dot, dot, dot...dash, dash, dash...dot, dot, dot
or is that save our supra? lol jk.
and back to the subject. i would set the timing back how it should be and if you get code 52 i would do the KS rewire i believe shaeff sells a kit as well. also fix both the codes check the wires at the AFM and the tps probably needs to be adjusted for the code 51
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=FI&P=101 good luck!
