It will not be able to auto-adjust enough. If you want to run 14.7, I suggest you turn off all Part Throttle Tracking and let the 7M ECU do it's job. It is very good, and very stubborn and persistent about maintaining that ratio, lol.
You must have a narrowband O2 sensor still installed for this to work.
Main scale works by adjusting the overall amount of air that the maftpro tells the ECU it's getting across the entire range. If you double this number, the ECU will think that twice the amount of air is coming in than before. When you add bigger injectors to this mix and leave everything as-is, the ECU is going to make the injectors fire for the same duration as before, but you're going to get far more fuel dumped in. Going from 440's to 870's, you'd get pretty much double (870/440=1.97) the fuel going in.
Therefore, you need to tell the engine that it's getting about half the amount of air that it really is, so it fires the injectors for only half the time it otherwise would and you get back to a normal fuel mixture.
Try searching for threads that include 'maftpro', 'injectors', and 'mainscale', and you'll get a lot more info on this exact topic. Lots and lots of people go from 440's to 550's or 680's, and have to back off their mainscale to accommodate.
