Spec vs ACT
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
So I'm looking to buy a new clutch for my 1989 Mk3 7mgte, Looking to get about 500 Whp once it's all done.
Clutch Options:
ACT:
Torque rating of 522 ft/lbs.
Disc Material Ceramic
http://store.driftmotion.com/static/i-ts2-hdg6.php
Spec:
Torque rating of 520 ft/lb
Carbon-Graphite Friction Material
http://www.coolcarpartsonline.com/c...utches/toyota-supra-86-92-spec-clutch-stage-3
Which should I go with? I was wondering which would hold up better and better quality. Also the diference between Ceramic and Carbon? Durability?
aye mate
Hiatus over.
Maryland
I have a Spec stage 2 and never had a problem with it. Not sure if the controversy is still around, but when I was researching clutches some people said that Spec uses an OEM PP painted blue. The pedal feel with my stage 2 is no different than stock.
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
From what what I know all of them use stock pressure Plates but there suppose to be modified for higher clamping.
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
Yes Sir
Daily driven once in a while and weekend Drag Racer, im a really heavy foot though.
IBoughtASupra
4,455
Queens, NY
Get a better clutch then. It is better to get something that is not just a little above what you need. The reason for this is because drag racing and slipping the clutch adds a lot of heat and stress, so if you are making 500TQ, get a clutch for 600TQ. It is the same concept as fuel, always want more than you need.
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
IBoughtASupra;1799656 said:
I actually have a HPF clutch disk and ACT pressure plate that will hold all the power you have/plan to make before needed a twin disk.
How much does that HPF setup run for?
Good point on getting a higher rated Tq clutch setup, would be nice to have something a bit more reliable.
jdemara
285
North Delta
Is that sprung or unsprung? what is the engagement like? any chatter?
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
I'm running the ACT XT pp with 6-puck sprung disk. My little torque-less 1JZ is making about 500lb/ft and its holding up great, street friendly..not so much better start working out your left leg
