spec clutches
bluepearl
326
pa.
I run a spec stage two. The clutch is stock like, with almost no added pedal pressure and no chatter. I have about 300 lb. feet of torque and it works fine. Breakin is critical, and I don't beat my car to death. You will get various opinons on this clutch. For lower power levels, I say thumbs up.
WA
i have the spec stage 3 (6 puck). it has always had a bit of chatter but it holds like a sum uh a bitch. also stock like pedal pressure.
mkIIIman089
Ohio
I have a stage 2. It's always had some problem with a popping/snapping noise when you are moving the clutch pedal. I haven't been able to locate the problem and it doesn't effect performance...
In short, I'd be willing to recommend them.
I think he's saying that if you're making too much power for the stage three to hold then the tranny isn't going to be able to hold it either for an extended amount of time...................:dunno:
Dirgle
Conjurer of Boost
Pauma Valley, CA
Correct, as it is generally accepted that the W58 won't last much past ~400ft/lbs. for very long. So if you exceed the clutch you have probably exceeded the capability's of the tranny and it is on it's way out.
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
thanks, i completely forgot about that, well i dont have the funds for another tranny right now, so i guess, ill just have to see how it goes and be saving $$ during the process for the R154.
so is the spec clutch in the link provided a good choice then?
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
Fuzz420 said:
i got this in my basement sittin in a box waiting to be installled with a fidanza flywheel. Give me more time and ill tell you if it will hold 465lbs and if the tranny bust or not ;)
sweet, i take it you have the w58 then..
