Spark plug gap
1-2clutch-u
379
chi town and ohio
Just ordered New ngks. I know the book says .032 but I think I should be a bit tighter. Im bpu++ if that helps (bpu old skool lingo lol) aka intake exhaust Ic more boost.:icon_bigg
I6Boost
182
My Supra
How much boost?
When your increasing your boost, majority of the time you
will want to reduce the plugs gap by a little to keep from blowing
the spark out.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
it is 30 not 32 32 is for n/a
mine is gaped to 28
remember if you leak marks on the ground electrode that will leave a chanc3e of haven hot spots
gottadiesel
Flyin Low
Feb 16, 2009
459
Vancouver, Washington
Not that this really applies to his real question, but in case someone comes across in their search for stock gaps - 1987-1988 TRSM (which OP has 1988) page IG-8 states:
7MGE 1.1mm / .043 in
7MGTE .8mm .031 in
I am currently running at .28 but have not broken 6psi of boost yet (still in break-in), from what I understand, but double check for yourself, when you get into the mid-teens on boost need to get down to .26 and even is low as .24 when you start getting to that 20 psi point. But I assume every car and setup will be a little different...
