I just pulled out all my plugs to inspect the condition of my car... Well not so great news... All of them were pretty much black and had carbon all over them. It leads me to think that I'm burning oil... Alot of it b/c some of them are even slightly wet. I'm running crazy heavy oil 20W/50 + Lucas
It's not the valve cover gaskets nor the valve stem seals, as they were replaced. After cleaning the spark plugs, the car started much easier. It didn't need a 2nd cranking.
If it were burning coolant, would the spark plugs be clean?
Also, when i look into the spark plug hole and see the piston, is it suppose to be wettish looking after the engine has warmed up? I defintely see a lot of carbon build up in there.
Does this sound like worn valve guides
... I should do another compression test, but there seems to be so much carbon buildup in there that it will screw around with my results.
This car has been a real pita... I haven't even registered it on the road yet in the 3 years of owning it
Thanks.
Thanks.
